HPL1710 Yellow Screen Problem
Meh IDK that Please I need your help maybe you need to put VGA well
Esta é uma boa pergunta?
@austuriface this will depend on how yellow your screen is. If it looks like a smoked yellow, it will be the backlight. The HPL1710 uses CCFL backlight. Aging CCFL tubes will create a yellow screen. Replacing the CCFL tubes will remedy this.
If the screen is a bright yellow and adjusting the colors in your menu does not change it then the issue is most likely the main board. Having worked on this monitor model a lot, my money is on the CCFL tubes. It will help if you post some pictures of what your screen actually displays. That way we can be 100% certain.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 41
Ao todo: 114
2 comentários
Can you try to explain more, we can't help you if you just say "Meh IDK that Please I need your help maybe you need to put VGA well"
por Albert Einstein Compartilhar
Hi @austuriface
Have you tried connecting a different , known, working vga cable to the monitor and checked if the display is OK?
Have you tried connecting the monitor to a different computer to check if the problem is the monitor or the first computer?
What have you tried?
por jayeff Compartilhar
