Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Xbox One S. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Xbox One S.
No picture when turned on
Hi I have the Xbox one s as an old console and I turn it on but has no picture showing on TV and HDMI port is still good I have tried both hdmi ports and new cables and nothing I have also tried putting it into low resolution mode and all other modes and nothing do you guys have any clue (I have recently switched to new gen but need old one running so I can clear it because I have card details on it etc)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
I know this sounds weird, but it could be caused by a broken HDD.
I repaired many of them with exactly this fault. When the HDD is gone, it’s trying to boot and get the bootanim from the HDD and then load the dashboard. When it’s unable to do so, it just shows “no signal” on the TV, no matter what you do.
Luckily, testing is very easy.
Remove the old HDD, and just put in whatever HDD (empty) you got. It should give you an error now! This means that the old HDD is broken and need to be replaced.
You can follow this guide for that: Substituição do disco rígido do Xbox One S
I highly recommend to install a new SSD at this point (first lookup which SSD’s are compatible). It’s way faster, less heat, more efficient etc. After you got the new SSD/HDD, you need to prepare it and configure the new drive with a script. Follow this guide for that: Instalação de firmware no Xbox One S
Transfering the bootanim.dat from the old HDD if your Windows Laptop/desktop (if still possible!!) is recommended but not required. Without this, it’s just showing a black screen when booting up (but it will load the dashboard after this).
Then put the software on the USB and complete the install on your Xbox One S :).
IF, it did not show any errors when trying a new empty HDD, it’s most likely the HDMI IC that need to be replaced on the motherboard. This requires soldering and soldering experience to get the job done. But try the HDD method first!
Please let us know how it goes :)!
Imagem de Xbox One S Disco rígido
Guia
Nível de dificuldade:
Moderado
30 minutes - 1 hour
Guia
Difícil
30 minutes - 1 hour
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Owen Ritchie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 42
Ao todo: 42
