Ir para o conteúdo principal
Factory reset without a recovery key
My laptop is locked because I don't remember the password and I no longer have access to the Gmail account or the Microsoft account-.So how can I do it by using a computer?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Depending on what you see, it might be recoverable. If it's just a forgotten password and you made a password reset key you can use that to reset it otherwise you can use this trick (make sure to undo it!): https://www.youtube.com/watch?v=0gOZoroP... -- if it's just a password, use that loophole. If it's BitLocker and you lost the key, you will need to erase the machine. KonBoot also works, but it might break TPM bound data in Win11, I know it broke TPM bound data when I had to KonBoot a Dell with a bad BIOS I put into another PC we forgot the password on, but that was probably because I switched boards.
If the machine is unrecoverable, use the MCT to write a bootable drive and reload Windows: Windows 10/11 - Criação de mídia de instalação USB (Rufus)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Eddie S. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 22
Ao todo: 67
