Ir para o conteúdo principal
Computador desktop eMachines 2220.
Why does mine keep giving a boot error
Imagem
Its something with the disk drive but it says something about master and slave slots
Update (06/16/26)
Turns out it was a dead cmos battery
Esta é uma boa pergunta?
Pontuação 1
5 comentários
What is the actual error message? Does the computer keep restarting after the error message?
por Compartilhar
It also doesn't read the disk drive
por Compartilhar
Are you able to enter the bios by pressing DEL button upon startup and look at your boot priority? You can disble the disk drive which could interfere with your boot sequence
por Compartilhar
I was able to and doesn't read the hdd it reads disk sorry for inconvenience
por Compartilhar
Try holding down the shift key when turning on your computer and see if it takes you to the advanced boot manager.
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
@caseyteska36918 your computer does not "see" the boot disk. Either you have a bad HDD/SSD or corrupted OS boot files. Enter your computer's BIOS on startup and check the boot sequence to make sure it is not configured to boot from a Network. Make sure your hard disk is listed in the boot sequence. Make your hard disk the first device in your boot order. If is is bing seen etc. then you could try to repair the OS or reinstall it. Also reset your BIOS to factory default settings.
If your Boot drive is not visible it will have failed. In that case you would need to replace it and reinstall an OS.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Prob a bad hdd because the computer tower has the original hdd and it's from 2008 so could be
por Compartilhar
@caseyteska36918 yeah, that would be my first guess be as well.
por Compartilhar
Yea it's probably a bad hard-drive but it's not clicking like how bad ones do so might be corrupted
por Compartilhar
Pontuação 1
1 comentário:
@caseyteska36918 definitely unexpected :-) but glad you got it figured out and fixed!
por Compartilhar
Adicionar a sua resposta
Casey Teska será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 174
