Ir para o conteúdo principal
Battery and charger type
Can i see a battery and charger
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@maoperorisang there are three battery options for the Dell E6330:
  • 3-cell (32 WHr) Lithium-ion battery with ExpressCharge
  • 6-cell (65 WHr) Lithium-ion battery with ExpressCharge
  • 6-cell (58 WHr) Lithium-ion battery
Common part numbers for the Dell E6330 are FRR0G, Y61CV, 09K6P, RFJMW, and KJ321.
For a picture of the battery check on here Not an endorsement of the seller.
The AC Adapter (charger) is a 19.5V 3.34A for the 65 W or a 19.5V 4.62A for the 90W. It has a 7.4mm x 5.0mm barrel tip. Common Dell part numbers for that are HA65NM130, LA65NM130, DA65NM130, HK65NM130, 6VN9R, JNKWD, 3F1CN, NVV12
For a picture of the adapter check on here Not an endorsement of the seller.
Use the "Working on Your Computer" chapters of the Dell Latitude E6330 Owner's Manual to work on your computer.
Esta resposta foi útil?
Pontuação 0
1 comentário:
The charger can even be one of the modern curved ones - these do not care beyond the genuine Dell signaling. The battery is what changed between the Ivy (30)/Haswell (40) series.
por
Adicionar a sua resposta
Maope Rorisang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 154
