Ir para o conteúdo principal
O Playdate é um pequeno console de jogo portátil retrô desenvolvido pela Panic e projetado pela Teenage Engineering. O Playdate foi lançado para encomendas iniciais em agosto de 2021.
A Battery Replacement Option
Just curious where you can order a replacement battery from. Thanks for your time & help in advance. - A friend
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hello,
Unfortunately neither Panic nor iFixit sells the part directly. If the device is still under warrenty, I would suggest that you contact the company directly and ask for a replacement. If not, here is some advice:
You'll need to open up the device, which is not very difficult. Here is a guide from iFixit: Teardown do Playdate
I did some googling, and I cannot find an exact battery as the one in the device. However, here is a very similar wattage and voltage battery. Just be sure that the measurements are correct and that the battery that you buy has all of the necessary protetctions (voltage under/overload, etc).
https://ydlbattery.com/products/3-7v-750...
Best of luck, and let us know if you have any other questions!!
Esta resposta foi útil?
Pontuação 3
1 comentário:
Hi @teardowns101
The battery you linked might not fit as there doesn't seem enough spare space to accommodate it, i.e. it's too wide and possibly too high.
The dimensions of the battery you linked are 5.0mm H x 30mm W x 48mm L (503048) whereas the dimensions of the battery as seen in the guide are 3.8mm H x 27mm W x 58mm L (382758)
Cheers
por Compartilhar
Adicionar a sua resposta
Author Fox será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 126
Ao todo: 963
