Ir para o conteúdo principal
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Perguntas Visualizar todos
Is it possible to replace the non-swappable battery?
I read somewhere that the battery on the new macbook pro (non-retina) is advertised to sustain 1000 charges. After the battery is dead, can I replace the "non-swappable" battery - by myself or via Apple care's services ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes, even though Apple puts a label on the battery that says non removable there is only one try-wing screw holding it in place and replacement are relatively easy to find because if has the same battery as the 2011 model. Apple also will replace your battery for (I believe) $200 at the store.
Hope this helps
Esta resposta foi útil?
Pontuação 5
1 comentário:
Yes, you're right. Also, I add that, of course, when the Macbook is still on warranty, servicing it at home may void the warranty, so, it's a good advice letting the Genius Bat techies do their job.
por
Adicionar a sua resposta
desafinado será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,497
