Ir para o conteúdo principal
Blue screen of death
Says bd705349 dcl and such
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
[image|3935181]
por
Adicionar um comentário
2 respostas
Solução escolhida
This is bad, very bad. Your machine lost key data on the TPM and now it wants a 48 character Bitlocker key, one which lost means complete data loss unless you can recover the key. See if you can get the key from this site if you used a MSA: https://account.microsoft.com/devices/re... -- if you used a local account, you're done unless you have a copy of the key locally.
If you can't get back in, use this guide to make a bootable drive: Windows 10/11 - Criação de mídia de instalação USB (Rufus) or Windows 10/11 - Criação de Suporte de Instalação USB (Microsoft MCT)
If you want to be sure sure the drive is clean, use this to securely wipe it: Diagnóstico e apagamento de SSDs e eMMC - Distribuições baseadas em Debian, Parted Magic Legacy e builds de 2026+
I have seen this on the 64X G9 and G10 series (not my G11) but you probably should buy a mouse... Some Synaptic chips do not work well in the installer, and my HP G9 series machines were there, G6 and older weren't affected and G11 fixed it again.
Imagem de Windows 11
Guia
Nível de dificuldade:
Fácil
30 minutes - 1 hour
Imagem de Linux
Guia
Fácil
1 - 6 hours
Guia
Fácil
30 minutes - 1 hour
Esta resposta foi útil?
Pontuação 3
I HAVE NO KNOWLEDGE OF BITLOCKER AS I HAVE NEVER USED IT
According to the image provided, you need to enter a security key. Microsoft says at aka.ms/myrecoverykey, you can find the key at https://account.microsoft.com/devices/re... if it was linked to your Microsoft account. If it was linked to a work or school account, go to https://aka.ms/aadrecoverykey. Printout and USB drive options are available so I would look for any items. If you cannot access or find your key, you will have to reset your computer which will erase all of your data.
I’m sorry if this does not work or the outcome has disappointed you, I’m only young (teenage), or if it has you are very welcome.
Pontuação 0
Adicionar a sua resposta
Casey teska será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 228
