Ir para o conteúdo principal
Playback error with YouTube tv
Suddenly I get a playback error with YouTube tv when using my Epson 3800 projector. Worked fine until recently. No issues on tv's, just my projector. Any solutions?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@shawneesteve does this only happen when using Youtube for playback?
por
It happens when I try to watch live tv on YouTube TV. The other apps like Prime or Fubi work fine.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
It might be an HDCP error. Unless it has HDMI, HDCP support is not always present. What Epson projector do you have? Is it the Home Cinema 3800 or another model? Epson 3800 is ambiguous at best.
I have seen all of them (Dell, Epson, and the many others) produce VGA "EDU" projectors long after the mainstream got past VGA where HDMI became standard, and they flood the market when the schools dump them due to bad lamps and no HDMI many times. As much as I promote reuse, please do not buy these things*. They're not worth buying when HDMI models are as cheap or not much more then these compromised EDU models.
*They are fine for things like old game consoles except cases like the PS3 where you need a HDMI "splitter" or straight up stripper as the HDCP is always on, but old consoles and such are fine and work fine as they do not have HDCP dependencies.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Shawnee Steve será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 26
Ao todo: 243
