Ir para o conteúdo principal
O Google Pixel 7a é a variante voltada para o custo-benefício da série Pixel 7. Lançado em maio de 2023, o Pixel 7a traz melhorias em relação ao Pixel 6a, como sistema de desbloqueio facial, 8 GB de RAM, câmeras com grandes melhorias e carregamento sem fio.
Restocking of the battery
Hi there,
Got a swelling battery, was able to remove it with your tutorial before it gets worse, then wanted to buy a replacement one but you're out of stock.
Do you know if you'll be able to restock or is itgoing to be a long time shortage. Seems a stupid question but in France google dont do the battery replacement, and i dont know if it's due to a mass shortage.
Thx a lot.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Swelled battery cannot be recovered, it's depleted completely. If you can't find a spare part, temporary solution may be using universal battery with similar size. It will reduce the capacity and maybe require some supports to hold the battery, but device will work. Sometimes you must take a controller from an old battery, if it refuses to start, and change only bank of the battery.
por
Adicionar um comentário
2 respostas
Solução escolhida
@seeyounexttime that is a question that only the iFixit associates can answer. Most of us on here are volunteers and not directly connected with the business iFixit. You can get in touch with iFixit by using the customer service form
Esta resposta foi útil?
Pontuação 3
Hi @seeyounexttime
Search online for GP5JE battery France to find suitable suppliers if you can't get one from ifixit within a suitable timeframe.
Pontuação 0
Adicionar a sua resposta
Rerholl será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 242
