Ir para o conteúdo principal
A Sony Cyber-shot DSC-WX80 é uma câmera compacta capaz de capturar fotos nítidas em todos os tipos de luz, e que também inclui Wi-Fi.
How is SD card insert in camera
SD card is not readind
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Until ~2010, Sony cameras were notoriously incompatible with memory cards other than Memory Stick - Sony stopped making them in 2010, so all that's left is that card with a little wear from your PSP, NOS, used cards, and Chinese junk. I wouldn't buy one of these without confirming SDHC support; SDXC is a bonus. The exception is if you are using it for retro-style photos and can bear the risk of a Chinese card failing. This doesn't have that issue being new enough.
It's under the battery cover. On the Sony a6300 for example, this is how the card goes in:
Imagem
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hariram Vishwakarma será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 170
