Ir para o conteúdo principal
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
Unable to connect to Internet
When I try to use the internet I get a message stating that there is a "Connection Problem" or " Could not establish a secure connection ".
I have done a factory reset and the wifi is connected with a strong signal.
I tried speaking to Samsung but they were not helpful.
The tablet switches on and seems to function OK and I would just like to get some more use out of it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @jpenn74640
Try starting the tablet in safe mode and check if you can connect to the internet OK.
Here's an article that details the procedure to enter and exit safe mode
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you for this suggestion but unfortunately it did not solve the problem
por
Has the tablet been opened?
por
Adicionar a sua resposta
J.Penn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 157
