Ir para o conteúdo principal
Laptop FHD de 15,6” e 144 Hz com processador Intel i5-13450HX, placa gráfica RTX 3050 6GB, 8GB DDR5, SSD de 512GB, Windows 11, bateria de 60Wh e adaptador de 170W.
How do I clean the fans?
My LOQ 15IRX9 fans haven't been cleaned since it was bought, and I can see some dust building up on its bottom cover. I want to know how I can clean the fans on the inside by myself. How do I do it properly?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @kialzi
Here's the hardware maintenance manual for the laptop.
Go to p.42 in the manual (48 of 68 pdf) to view the procedure to remove/replace the thermal module.
Once it's removed this will allow you gently clean the fans away from the other components inside the laptop.
Also once it has been removed, check the condition of the thermal paste on both the CPU and the GPU to make sure that it hasn't dried out and needs to be refreshed.
Here's the ifixit Aplicação de pasta térmica guide that may help with this.
Esta resposta foi útil?
Pontuação 2
Open the laptop up(just unscrew everything on the back and use a small pick (can be a guitar pick) to open it and then just vacuum the dust out
You can also put a new SSD in (2242 or 2280)
Pontuação 0
Adicionar a sua resposta
Kialzi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 33
Últimos 30 dias: 178
Ao todo: 2,189
