Ir para o conteúdo principal
Guias de reparo para o Microsoft Surface Laptop Studio. Lançado em setembro de 2021 e identificado pelo número de modelo 1964.
Surface studio spilled juice
Spilled ice tea on my surface studio the laptop was not on when I spilled liquid on it. When I tried turning it on the widow logo would show for 2 seconds then screen would go black. Now it totally black won’t turn on at all. Is there a proper way to clean inside of laptop ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @prince65238
The impurities in the iced tea causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your laptop anymore and then disconnect the battery as soon as possible from the laptop to minimize any further damage.
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and liquids. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the liquid may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this it might possibly work correctly again.
Here is the ifixit Microsoft Surface Laptop Studio guide that may help.
If this process seems too daunting, take your laptop to a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Prince será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 224
