How do I reset this pc?
i tried doing a normal reset from setting, 'recover option' but it does not provide me with the right options
Esta é uma boa pergunta?
With Windows, this is a massive red flag and usually points to a tampered or damaged OS installation, but it's generally caused by tampering. Since you are erasing it anyway, the only way to be sure with that kind of issue is to erase the PC and reload Windows from a USB drive. Backup your files first of course, but the only way to be sure is a wipe and reload.
Use this link for Windows 10: Download Windows 10
For Windows 11: Download Windows 11
Write the OS image to a USB drive and delete all of the partitions - do not keep anything given the high risk of tampering.
What I have done with machines that show this with an SSD is I will wipe the PC out with a tool that does an NVMe Secure Erase or ATA Secure Erase to be sure the drive. The exception is spinning rust - 3+ hours is excessive. I personally use Parted Magic.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 210
1 comentário
@mrmonyi what OS are you using and what options does in NOT provide?
por oldturkey03
