Ir para o conteúdo principal
O Dell G15 5515 é um notebook lançado em junho de 2021, criado pela Dell com o número de modelo 5515. Esta página existe para fornecer aos usuários do Dell G15 5515 correções simples e fáceis para problemas técnicos comuns.
Water Damage, still usable!
Every since I got some water damage on my laptop, the GPU is no longer detected. If you push on the righ part of the case of the laptop, you can cause a short and immediate black screen shutdown. The laptop still works amazing for CPU only tasks and even mild gaming, the battery life obviosuly improved with no GPU😂
I've been living with this for around 6 months and now I'm becoming interested in troubleshoot the MOBO and soldering if needed to fix my laptop! any reccomendations?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@jacobfromerth my number one recommendation would be to start disassembling your laptop. Use this Dell G15 5515 Service Manual to work on your laptop. Remove the motherboard and then it's time to clean it. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide It was written for an Apple iPhone3G but all the points are still pertinent to your motherboard as well.phone. While you clean your board, check for any obvious damage, like burned or missing components etc.
Until it is cleaned, everything will only be a guess. Post some well-focused pictures of your motherboard with your question. That way we can see what you see Adicionar imagens a uma pergunta já existente and hopefully we can help you getting this back to "normal"
Imagem de iPhone
Guia
Reparo de danos por líquido em iPhone
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jacob Fromerth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 331
