Changing front bumper out
Replacing front bumper, thanks
Esta é uma boa pergunta?
@simon52118 these don't have much of a bumper behind the cover. You'd be more looking at the radiator grill. Anyhow, this from the service manual 2014 to present:
1. Front bumper cover
2. Front bumper side bracket
Replacement
1.Loosen the front bumper upper mounting clips.
2. Loosen the front bumper lower mounting clips.
3. After loosening the front bumper (A) side's mounting clips and screw, then disconnect the side's.
4. Disconnect the front bumper main connector (A).
5.Remove the front bumper cover (A).
6. Install in the reverse order of removal.
If this is not the right model, then you need to let us know the exact year for your Sonata!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 33
Ao todo: 676
2 comentários
Hi @simon52118,
What is the year model of the vehicle?
por jayeff
Also, are you referring to the metal bumper itself, or just the bumper cover that goes over it?
por Jerry Wheeler
