Porque ele não liga?
Meu filho sentou em cima dele sem querer e fez xixi, ele estava ligado e na capa magnética e agora não liga mais, o que fazer? Tem conserto?
Esta é uma boa pergunta?
@carolpessanha you got to treat it like any other liquid damaged device. For now, you will need to stop continuing to try to charge, sync or otherwise use your tablet. This potentially can make a bad situation worse.This may further damage your Samsung Galaxy Tab S6 Lite.
The next thing to do is to clean it. Since iFixit does not yet have a guide for this, use something like this video to disassemble it. Once it is disassembled you need to remove the EMI shields from the motherboard. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide Even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc.
I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. When it is properly cleaned, replace the battery. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your tablet and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, liquid damage has only a small chance to be fully repaired, but at least you can give it a try.
Repair is War on Entropy!
Translation
@carolpessanha tens de o tratar como qualquer outro dispositivo danificado por líquidos. Por agora, tens de parar de tentar carregar, sincronizar ou utilizar o teu tablet. Isto pode piorar uma situação que já era má e danificar ainda mais o teu Samsung Galaxy Tab S6 Lite.
A próxima coisa a fazer é limpá-lo. Como o iFixit ainda não tem um guia para isto, usa algo como este vídeo para o desmontar. Uma vez desmontado, tens de remover as protecções EMI da motherboard. Se não as removeres, mais vale não fazeres nada. Depois de as removeres, limpa toda a placa, conectores e tudo o resto com álcool isopropílico a 90%. Segue o [guia|5825|este guia] Apesar de ter sido escrito para um Apple iPhone 3G, todos os pontos são pertinentes para o teu telemóvel. Enquanto limpas a placa, verifica se existem danos óbvios, como componentes queimados ou em falta, etc.
Não posso sublinhar o suficiente a importância de uma boa limpeza, por isso faz isso várias vezes, substituindo o álcool após cada limpeza. Quando estiver bem limpa, substitui a bateria. O melhor seria limpá-la com um aparelho de ultra-sons, mas se não tiveres acesso a um, isto pelo menos ajuda. Quando tudo isto estiver feito, volta a montar o teu tablet e volta a avaliar. Enquanto não o limpares, tudo não passará de uma suposição. É possível que tenhas um LCD estragado e que a substituição do conjunto do ecrã possa resolver o problema. Mesmo com tudo isto, os danos causados por líquidos têm apenas uma pequena hipótese de serem totalmente reparados, mas pelo menos podes tentar.
A reparação é a guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 309
