Ir para o conteúdo principal
Informações de reparo para a impressora jato de tinta fotográfica multifuncional Canon PIXMA MG6660.
Where is the WPS button
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@ericliddell should be in your settings menu. It does not look like your printer has a physical button. Let's assume you are trying to setup a wireless connection. use the instructions from here You can also download the MG6600 series Manual from here It will help you with your setup.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Every printer I've had doesn't use a button, it's always in the network setting. Don't have a demo Canon, but I do it on the HPs from Network>Wireless setup wizard for the screen versions or WPS on some old 2-liner models. My gently used (with a bad imaging drum) monochrome laser uses the app under Network unless you enter it manually or use WPS.
I suspect Canon is similar.
por
Adicionar a sua resposta
Eric Liddell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 32
Ao todo: 377
