Why does my phone keep restarting
Keeps restarting every 3 minutes and says panic full cpu 3
Esta é uma boa pergunta?
This should help you read the panic log and diagnose the issue. https://www.youtube.com/watch?v=C2687jnf...
From what I've seen in my shop, the most common cause for a 3 minute restart is an issue with the charge port. Just be aware this piece of software isn't always accurate, and does require further diagnosis, it's a tool used to help narrow down what the issue could be.
Esta resposta foi útil?
iPhone 14 keep restarting if there's an issue with the wireless charging/rear mic/flash.
You can reproduce it by disconnecting the flex cable.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 368
post the full panic log
por daniel
Well, probably don't need the full log, but at least the first page or so.
por Jerry Wheeler
