Ir para o conteúdo principal
Apple's smallest iPhone 14 was released on September 9th and comes with a 6.1" OLED display, an advanced dual 12 MP camera system, and a front camera with autofocus. Successor to the iPhone 13.
20 Perguntas Visualizar todos
Why does my phone keep restarting
Keeps restarting every 3 minutes and says panic full cpu 3
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
post the full panic log
por
Well, probably don't need the full log, but at least the first page or so.
por
Adicionar um comentário
2 respostas
This should help you read the panic log and diagnose the issue. https://www.youtube.com/watch?v=C2687jnf...
From what I've seen in my shop, the most common cause for a 3 minute restart is an issue with the charge port. Just be aware this piece of software isn't always accurate, and does require further diagnosis, it's a tool used to help narrow down what the issue could be.
Esta resposta foi útil?
Pontuação 0
iPhone 14 keep restarting if there's an issue with the wireless charging/rear mic/flash.
You can reproduce it by disconnecting the flex cable.
Pontuação 0
Adicionar a sua resposta
Noah será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 108
