Ir para o conteúdo principal
Processador quad-core Intel Core i7 de 2,0 GHz, 2,3 GHz ou 2,6 GHz (Turbo Boost de até 3,8 GHz) com 6 MB de cache L3 compartilhado.
help to identify MacBook Pro RAM chip
Hello!
These are RAM chips from my MacBook Pro 15" Retina Display Late 2013, it has 8 GB RAM & there are empty places on board to add more RAM chips to make it 16GB.
Please help me to identify this chip. No proper results in search engines.
Thank You _/\_
Imagem
Update (12/20/23)
logic board has number 820-3662-A
Update (12/31/23)
Thanks @oldturkey03 I could successfully upgrade my macbook RAM from 8 GB to 16 GB!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
What is the motherboard number? It is printerd on the motherboard and starts with “820-“
por
@v1ny4 woop woop and that's how it's done!!!! Awesome!
por
Adicionar um comentário
1 resposta
Solução escolhida
@v1ny4 You already know that those are your DDR3-1600 SDRAM IC's. The particular ones in your image are made by Micron. The D9QBJ is the FBGA code and the IC part number is MT41K512M8RH-125:E. (512MB IC's) They are available at places like this Here is the datasheet for the modules MT41K256M16 MT41K1G4 MT41K512M8 DS
Esta resposta foi útil?
Pontuação 2
5 comentários:
@oldturkey03
Great! Thanks!
So if some other chip says D9QBJ, is it same as one I have ?
6HEI7 is not important ?
por
@oldturkey03
Chip that says 7BEI7 D9QBJ should work ?
por
@v1ny4 check the datasheet :-) Those are most likely the Micron manufacture codes. For this IC the only real identifier needed is the D9QBJ
Repair is War on Entropy!
por
@oldturkey03 thank you _/\_
por
@v1ny4 you are welcome brother/sister fixer!
por
Adicionar a sua resposta
Vin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 519
