Ir para o conteúdo principal
Modelo A1224 / Início de 2009 / Processador Core 2 Duo de 2,66 GHz
How do I fix black screen?
Here are the symptoms:
-When you press the power button, the screen flashes white twice, then stays black. Otherwise, everything else starts up normally with the chime and hard drive sounds, etc.
-Shining a flashlight to the screen shows it still works (just no backlight?)
-I've reset the PRAM, no go
-I've replaced the inverter board but that didn't work
-It does work with an external monitor attached
I am currently running an extended Apple hardware test to see if it brings up anything specific.
Could something on the logic board be bad?
Bad CCFLs?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
The hardware test did not find anything. Bummer.
por
Adicionar um comentário
1 resposta
Solução escolhida
It's the screen connection to the board, screen or video card
Here is the screen guide, take it apart and check the screen connector, if nothing, try a a screen
Substituição do painel do display do iMac Intel 20" EMC 2266
If not, it's the video card or logicboard(I think this model has a MXM card)
I do not know much about the video card built onto the board or a seprate card, but I know this, if it's a ATI(AMD now) or NVIDIA, it's probably on a separate board, if it's intel, no, on the logicboard itself, you will need to take your iMac apart to know for sure about this
Here is the GPU swap guide
Substituição da placa de vídeo do iMac Intel de 20" EMC 2133 e 2210
Imagem de iMac Intel 20" EMC 2266 painel do display
Guia
Nível de dificuldade:
Moderado
Imagem de iMac Intel 20" EMC 2133 and 2210 Placa de vídeo
Guia
Moderado
1 - 2 hours
Esta resposta foi útil?
Pontuação 0
1 comentário:
thank you nick, i really appreciated you, its also solve my problem
por
Adicionar a sua resposta
mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 2,716
