Ir para o conteúdo principal
A HP Envy 4520 é uma impressora e scanner multifuncional sem fio fabricada pela Hewlett Packard (HP). Foi lançada em agosto de 2015 e pode ser identificada pelo número do produto F0V69A#B1H.
ink cartridge connection problems
Replaced ink cartridge and continuous remove and reinstall ink cartridge?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@tomakers I just have a feeling here......try an original ink cartridge. I think this is one of those models that utilized blackmailing by parts serialization. Not using original overpriced HP cartridges=not allowed to function anymore!
Esta resposta foi útil?
Pontuação 1
1 comentário:
It's probably the 3rd party cart. HP has had the DS problem since like ~2017, but the integrated head carts can't be chip swapped like the toner based machines and split printhead models.
It just reads empty, and this predates HP+. If it was HP+ era I may suspect it was enabled. About the only thing they accomplished with HP+ and HP DS is lost loyal customers and only kept the Walmart customers; anyone with a brain has moved on, myself included. I know once I seen how awful HP DS is (they literally block print operation with a chip issue on the lasers and assume counterfit) that was truly it for me.
por
Adicionar a sua resposta
Tom Akers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 355
