Ir para o conteúdo principal
Informações de reparo para o iPod nano de 6ª geração. Lançado em setembro de 2010. Número do modelo: A1366.
How do you reset to factory settings
I tried down loading music to my Ipod but first my coputer asked me to reformate so I clicked yes
now it does nothing
can't even turn it off.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
gilbert, try this from here. "Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Esta resposta foi útil?
Pontuação 3
http://ipod.about.com/od/restoreandrefor...
You may try, if your iPod doesn't work but is seen by iTunes, using the "Restore" button in the iTunes menu. It'll give a proper reformat to your unit.
Pontuação 2
Adicionar a sua resposta
gilbert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 26,736
