What is causing Paper Jam Tray 1 or Tray 2 but is none
Laserjet 2300dtn, every attempt to print or test paper path gives jam error. Pickup rollers do not move at all. Cleaned and repaired "sticky" solenoids. Verified no broken gears or shafts. Everything sounds good and moves on startup except pickup rollers and comes up ready. Attempt to print throws 13.01.00. New Toner cart, verified no residual paper in path. Where to look or whats wrong? Thanks in advance.
Esta é uma boa pergunta?
1 comentário
@oldturkey03 Got it. I suspect the rollers are shot or improperly mounted... These are NOT fun to swap on Tray 2, unlike modern units which I still consider "good", so essentially all units which are reasonably new that also predate the M402 and color DRM machines (as in low PC pre-DRM).
That said, I'd still swap the rollers on a 50k+ page Pro 400 or a 150k+ page machine from the chipless era (or at least lack of DRM); but I'm not just grabbing one well run Pro 400 -- I need to make it worth the trip (and potential back pain). Can't hurt something with 150k pages as a bulk unit on the clock much worse if it's a bonus grab ;).
por Nick
