Ir para o conteúdo principal
The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
not holding the time & date
Although I did replace the battery, this has not solved the problem as it continues to not hold the date/time, but this information has to be reentered each time the camera is turned on again.
Please advise.
Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The CMOS battery is dead. On these, the battery is actually user serviceable (rare with Canon; they seem to go back and fourth a lot so when you have this you did well) so it can be done quickly:
Canon PowerShot SX160 IS Clock Battery Replacement
As far as buying the CR1220 for the swap your best bet is batteries+bulbs. This is a weird battery you do not see in most big box stores. You may get lucky at a drug store like CVS or Walgreens but this is not something you will find at Walmart.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Lee Wright será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 430
