Ir para o conteúdo principal
Canon PowerShot SX160 IS Clock Battery Replacement
O que você precisa
  1. Canon PowerShot SX160 IS Clock Battery Replacement, Clock Battery: passo 1, imagem 1 %32
    • Locate the internal battery tray on the side of your camera.
  2. Canon PowerShot SX160 IS Clock Battery Replacement: passo 2, imagem 1 %32
    • Use your finger or a spudger to gently pry the battery tray out of the camera.
  3. Canon PowerShot SX160 IS Clock Battery Replacement: passo 3, imagem 1 %32
    • Fully remove the battery tray from the camera.
  4. Canon PowerShot SX160 IS Clock Battery Replacement: passo 4, imagem 1 %32
    • Remove battery from tray and replace.
Conclusão
Congratulations, you have successfully replaced the internal battery. To reassemble your device, follow these instructions in reverse order.
37 outras pessoas executaram este guia.
Jamie Secretan
Membro desde: 03/11/15
1.990 Reputação
Autoria de 6 guias
Equipe
17 comentários
Clear and simple. Thanks!
Jim - Responder
I had no idea! Thanks!
natorbett - Responder
Its not necessary to unscrew the tray.
Afzal Pawaskar - Responder
Thank you, Jamie!
Casey Cain - Responder
Gee I thought I am so glad I checked the Internet first...(before I threw it in the trash) that is how frustrating this was. Thank you everyone, I do love this camera
Barbara Rivers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 161
Duração total: 50,426
