Ir para o conteúdo principal
Informações de reparo para o laptop Dell Inspiron 16-7610, lançado em 2021. Ele também é conhecido como Inspiron 16 Plus 7610.
Possible to replace integrated webcam?
I suddenly started having issues with my internal webcam. All of a sudden it started being really blurry. I've tried cleaning the lens, but it does not work. I'm thinking perhaps a seal cracked and now moisture has gotten in there. Is it possible to replace just the internal webcam? Or do I need to replace entire screen to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@zak18311 you did not give us your laptops model number but selected the Dell Inspiron 16-7610. You can download teh service manual for that computer from here Looks like that model has the camera integrated into the display assembly (the bezel around it actually). the camera is available as a spare part here for example. So that means you could try and use some heat to soften the glue that the screen into the assembly. Probably not an easy task and might be risking breaking the display, but nothing wrong with trying.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Dell probably uses snaps on these, that's the best case though. If not, it's clips and (hopefully) weak adhesive.
por Compartilhar
Adicionar a sua resposta
Zak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 897
