Ir para o conteúdo principal
Reparos e informações adicionais para a geladeira GE GFE26JGM****, uma geladeira com degelo automático sem máquina de gelo ou dispenser na porta, disponível pela primeira vez em 2019. Esta página cobre informações para números de modelo que correspondem ao padrão GFE26JGM****.
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Imagem
Imagem
Update (05/05/23)
  • trying again
Imagem
Imagem
Update (05/05/23)
GFE26JGMWFBB is the model
Esta é uma boa pergunta?
Pontuação 1
3 comentários
can you add photos
por
@dougwilds i can't see them doug it just says image
por
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Doug Wilds será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 620
