Ir para o conteúdo principal
How do I replace the charging port?
Charging port damaged and will not charge with a cord attached. The cord slides out.
Esta é uma boa pergunta?
Pontuação 5
2 comentários
Hi @stephaniel52636,
What is the model number of the phone as there is a Moto G Stylus 2021 model and a 2022 model?
por Compartilhar
هذه المشكله من أهم المشاكل لواجهها
Translation Arabic - English
This problem is one of the most important problems to face.
por Compartilhar
Adicionar um comentário
4 respostas
Pergunta mais útil
@stephaniel52636 luckily the charging port is soldered to a daughter board. All you have to do is to replace this board. You are looking at something like this As for getting to the board use something like this video
Esta resposta foi útil?
Pontuação 1
First: use a toothpick to check if there is debris. I can't be build up, so pry a little bit. If that doesn't work, you can change the chargeport. Changing the chargeport requires knowledge of fixing phones. Seek a local phone repair shop.
Pontuação 0
Well this video might be helpful for you :https://www.youtube.com/watch?v=CGX0s44d...
Pontuação 0
Use wireless charger
Pontuação 0
1 comentário:
Hi @hollyhoffm84436
Might depend on which model version it is, as the OP didn't specify.
The Moto Stylus 5G (released in 2021) doesn't have wireless charging capability.
The Moto Stylus 5G (2025) model does.
por Compartilhar
Adicionar a sua resposta
stephanie l será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 2,749
