Ir para o conteúdo principal
Informações de reparo para a série de laptops Dell Latitude 6000.
How to fix dark screen?
My laptop turn on and to see what is on my screen, I have to use a flashlight, without the flashlight i can almost see nothing. The brightness is turned all the way up. This is happening a while now especially when I turn down the brightness of the screen. Can it be fixed without pulling up the laptop? help me.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
@tanaythomas this "I have to use a flashlight" means it is your backlight that is not working. That could be a issue with the physical backlight on your LCD panel. It could also be that this is related to the backlight circuitry on your motherboard or the cable/connector from your motherboard to your LCD. Right now I would like to say that this "Can it be fixed without pulling up the laptop" would be a No. You will most likely have to disassemble your laptop and even take some measurements with a multimeter.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tanay Thomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 227
