Ir para o conteúdo principal
Repair information for the Dell Latitude 6000 laptop series.
18 Perguntas Visualizar todos
How to fix dark screen?
My laptop turn on and to see what is on my screen, I have to use a flashlight, without the flashlight i can almost see nothing. The brightness is turned all the way up. This is happening a while now especially when I turn down the brightness of the screen. Can it be fixed without pulling up the laptop? help me.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
@tanaythomas this "I have to use a flashlight" means it is your backlight that is not working. That could be a issue with the physical backlight on your LCD panel. It could also be that this is related to the backlight circuitry on your motherboard or the cable/connector from your motherboard to your LCD. Right now I would like to say that this "Can it be fixed without pulling up the laptop" would be a No. You will most likely have to disassemble your laptop and even take some measurements with a multimeter.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tanay Thomas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 77
