Can I replace the battery?
Hi,
Can I replace the battery on my Nokia 8?
Esta é uma boa pergunta?
Hi,
Yes you can. If no guide on here search on YouTube to give you an idea of what's involved.
Esta resposta foi útil?
Also, as with any Nokia repair. Be prepared to kill the screen. Honestly. There is only about 1mm adhered down both sides of the screen. Go any deeper and you dig into the LCD killing it. Believe me, I know, I've done it. Be extremely careful removing it.
I can definitely change
@cellomania like my colleague @strongbow already said, it's replaceable. A bit of a PITA but doable Check this video
Of course, you can also use these images. Instead of a hot plate you can use a heat gun (low settings) or a good hair dryer.
When you replace your battery. Take lots of pictures and then create a guide, The iFixit community will greatly appreciate it. https://www.ifixit.com/Guide/new
Danke! sehr Hilfreich......
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 2,050
