Ir para o conteúdo principal
O smartphone topo de linha da Apple para 2021. Lançado em 24 de setembro, o iPhone 13 Pro Max possui uma tela OLED ProMotion de 6,7 polegadas, um novo sistema de câmera traseira tripla e conectividade 5G. Sucessor do iPhone 12 Pro Max.
fear of data recovery
i’m looking to give away my phone but my concern is the data that once stored and that i have factory reset it many times but my anxiety still crawls in. what are the ways of assurance or maybe a tips for me to get technical where i can replace a new data chip (not sure what its call, need your help on this)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Mhd Znd, Download 3uTools and connect your phone to your computer (Windows as 3uTools is for Windows).
When connected and authorised, you can enter the Flash menu. Download the latest iOS package in 3uTools (it will list out the compatible, signed, versions). There is an option there in the Flash menu, that is made to prevent the recovery of data. Select that option before clicking the Flash button!
NOTE! I haven’t done a recovery test on a device after using that option, so I can’t attest to it’s reliability personally!
Esta resposta foi útil?
Pontuação 2
You can rest assured there will be no way to access the data once the phone has been reset. Apple have designed there phones with security at the top of their list. There is an IC on the logic board called the “logic eeprom” it holds all the keys necessary to access your data, when the phone is reset so are the keys. Even the most sophisticated forensic software used by the law enforcements would not be able to access the data once the phone has been factory reset.
Pontuação 1
Think about it this way: If the FBI has to subpoena Apple to come up with a backdoor and they refuse to unlock the phone (which is possible because it is literally technically impossible since the PASSCODE IS USED TO ENCRYPT THE PHONE), there's zero chance of recovery once you reset the phone.
Apple designs the phones so that even they can't get into it if you forget something like the passcode; it HAS TO BE erased. The passcode is literally the encryption key with iPhones - without getting it from the phone's user all of the 3 letter agencies are unable to get in.
Pontuação 1
Adicionar a sua resposta
Mhd Znd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 330
