Ir para o conteúdo principal
Guias de reparo e resolução de problemas para o notebook gamer Asus Republic of Gamers Strix de 15,6" com o número de modelo GL503VM-B17N13.
Guide for re-pasting and cleaning
Hello,
I bought my Asus ROG GL503GE back on November, 2018. Since the last couple of days, the left CPU fan is making a faint buzzing sound, and the temps aren’t that great as those were before. I am thinking of cleaning and re-pasting my laptop. I am planning to use Noctua NT H1 for repasting.
So here are the questions:
1) Should I use isopropyl alcohol to rub off the old thermal compound? I heard some say that using alcohol might damage CPU linings (don’t know what they mean).
2) After disassembling the laptop and removing the power connector, is it a good idea to press the power button to drain the leftover charge from the capacitors inside?
3) Which order should I remove the screws from the heatsink? Are there any numberings on the screws?
I haven’t messed around with disassembling laptops that much. I would like to know the proper guide to remove various connectors inside the laptop. If there is any good thread/video about that, please share :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Anwarul Bashir Shuaib use this guide for the thermal paste Aplicação de pasta térmica I would definitely perform a discharge you listed with 2. You will be okay with pretty much going in any order to remove those screws.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Anwarul Bashir Shuaib será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 19
Ao todo: 680
