Ir para o conteúdo principal
O décimo smartphone emblemático da linha Galaxy da Samsung, lançado em março de 2019. Lançado com Android 9.0 (Pie).
Touch screen not working
Hi
I have a samsung s10 the touchscreen has stopped working. It started at the top of the screen and it now has spread to the rest of the phone. I don’t want to do a hard reset as I have been unable to send pics etc to the cloud, thanks
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Samsung s1p plus toch not working
por Compartilhar
El touch no funciona
por Compartilhar
Adicionar um comentário
3 respostas
Pergunta mais útil
Clare Birtwhistle, the only way to fix this “It started at the top of the screen and it now has spread to the rest of the phone” is by replacing the digitizer. In this phone the display assembly is fused so unless you have the tools to separate it etc. it’s best to replace the display assembly. Substituição da tela do Samsung Galaxy S10
Esta resposta foi útil?
Pontuação 2
Hi,
Connect a USB mouse to the phone via an OTG cable and use the mouse to navigate through the phone so that you can backup your data to the cloud. Search online for Samsung S10 OTG cable to get results for suppliers that suit you best.
Be aware that the phone’s battery is used to power the mouse so it will discharge more quickly than normal.
After that you can replace the LCD screen + digitizer as described above, to fix the touch problem.
Replacing the screen assembly doesn’t require a hard reset so if you are careful, your data shouldn’t be affected. If you backup your data first nothing untoward will happen to it because of the repair, but odds are if you don’t then it will. Murphy’s Law.
Pontuação 1
https://youtu.be/w1m47ALwjGQ
I solved my problem by this video
Pontuação 0
Adicionar a sua resposta
Clare Birtwhistle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 44
Ao todo: 4,890
