Ir para o conteúdo principal
Repair guides and support for Panasonic's Viera line of televisions.
417 Perguntas Visualizar todos
How to change aspect ratio on Panasonic viera th-50px80u
The aspect ratio on my tv is messed up (the picture is too big for the screen). Any idea how to fix the aspect ratio? Maybe by factory resetting? I know there's a "zoom adjust" option in picture settings, but it's grayed out, despite being for an HDMI input with a 1080p signal (a Roku). I don't have the remote, but will buy one if absolutely need be. Some picture for reference.
Esta é uma boa pergunta?
Pontuação 2
6 comentários
Hi@markdk,
Did you try Menu > Picture > Reset?
por
The reset button is also grayed out
por
I found this, also if you buy this hit the aspect button
https://www.newegg.com/p/17A-00GF-00464?...
por
Is my TV wifi friendly and can I cast from my phone
por
@joeycampbe83208 what make and model is your TV?
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
@markdk your 3rd picture shows the 2 screen for that menu. You did not show the first. Anyhow, as the manual states, you do that on the remote by simply pressing FORMAT and then cycle through the aspect modes. So, Looks like you will need it since the ZOOM,Hfill etc do not seem to appear on the TV screen settings.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Mark Kostyack será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 132
Duração total: 2,440
