Ir para o conteúdo principal
O Homelite UT44172 é um aparador de grama sem fio de 4,8 volts com uma bateria recarregável e lâminas de aço. Fabricado em 2010 pela Homelite. Atualmente descontinuado e substituído pelo modelo Homelite UT14474.
Were can I get replace battery
Replacement battery's for my cordless grass shear model ut44172
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I'm sorry but I can find no one that still carries batteries for this model.
por
Adicionar um comentário
1 resposta
Mary Brooks here is the bad news. Looks like this battery is no longer available. Good news is that this is iFixit. You know you can build a replacement by yourself. It is not as complicated or dangerous as you may thing. Take a couple of good pictures and post those with your question. It looks like you open it up the same way as on here Substituição das lâminas do Homelite UT44172 Again, take pictures if unsure. the black tubular thing is actually the battery. The black cover is just that, a plastic cover. Remove the battery by most likely unsoldering the wires. Ultimately I suggest you do something like this Substituição da bateria da chave (de fenda) Black and Decker 9074 just with the type of “batteries” that are appropriate for outr Homelite. Again, it is not as complicated as it may seem.
I would hate for you to discard these shears just because the corporation (Techtronic Industries who owns Homelite) has stopped supporting this equipment. Our landfills are full of stuff that can be fixed and used for many more years. Let us know which way you are going with that. We are always willing to help you and to save the world and humanity. One device at a time.
REPAIR IS WAR ON ENTROPY
Imagem de Black and Decker 9074 Type 4
Guia
Nível de dificuldade:
Moderado
30 minutes
Imagem de Homelite UT44172 Lâminas
Guia
Fácil
10 - 20 minutes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mary Brooks será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 847
