Ir para o conteúdo principal
Repairing Black and Decker 9074 Screwdriver Battery
O que você precisa
  1. Repairing Black and Decker 9074 Screwdriver  Battery, Repairing Black and Decker 9074 Screwdriver  Battery: passo 1, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery, Repairing Black and Decker 9074 Screwdriver  Battery: passo 1, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery, Repairing Black and Decker 9074 Screwdriver  Battery: passo 1, imagem 3 %32
    • Here is the original battery. Three cells surrounded by a soft plastic sheathing
    • Cut the plastic (I used a utility knife) away.
    • Now the three cells are clearly visible and the way they are connected in series. Meaning positive from one cell to negative on the next cell. Each cell separated by a rubber insulator
  2. Repairing Black and Decker 9074 Screwdriver  Battery: passo 2, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 2, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 2, imagem 3 %32
    • Top to bottom on this image shows the insulator that is on the top portion of the cells. Next are the old three cells and bottom the new cells.
    • The contacts on the old cells appear to be spot welded to make the connection.
    • Separate the connections with either a pair of side cutters or a pair of scissor. This will allow you to remove the insulators.
  3. Repairing Black and Decker 9074 Screwdriver  Battery: passo 3, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 3, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 3, imagem 3 %32
    • Here all the cells are separated and the insulator removed
    • Plenty of corrosion visible on each of the old cells.
    • To prepare the new cells, the heatshrink insulation from the contacts need to be removed. I used a utility knife to remove that.
  4. Repairing Black and Decker 9074 Screwdriver  Battery: passo 4, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 4, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 4, imagem 3 %32
    • Here is the first cell, insulation removed. Prepare all cells like that.
    • Align the positive contact of the first cell with the negative contact of the second cell.
    • Since the contacts will be soldered to each other, I did use some flux on the contacts prior to soldering.
  5. Repairing Black and Decker 9074 Screwdriver  Battery: passo 5, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 5, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 5, imagem 3 %32
    • Apply the flux to the contacts, in my case I used a cotton swab.
    • Once proper alignment is obtained, I use a alligator clip to hold them in position.
    • Now solder the contacts together. I used a 30watt soldering iron with a blunt tip.
  6. Repairing Black and Decker 9074 Screwdriver  Battery: passo 6, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 6, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 6, imagem 3 %32
    • Here is the first attempt. Luckily I noticed that I had forgotten to install the rubber insulator before going on to the next cell. Desolder the contacts to rectify this.
    • Here is the next cell properly prepared.
    • First two cells, separated by the insulator, soldered together.
  7. Repairing Black and Decker 9074 Screwdriver  Battery: passo 7, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 7, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 7, imagem 3 %32
    • 2nd and 3rd cell prepared and being aligned.
    • Applied flux and alligator clip to hold it in alignment.
    • Solder the contacts together
  8. Repairing Black and Decker 9074 Screwdriver  Battery: passo 8, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 8, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 8, imagem 3 %32
    • All three cells soldered together, positive to negative end, creating a series connection.
    • The original battery was wrapped in some soft plastic. I decided to use 1 1/4 inch heat shrink tubing. Black electric tape might work just as well, but I used what I had on hand.
    • Heatshrink tubing placed over the cells
  9. Repairing Black and Decker 9074 Screwdriver  Battery: passo 9, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 9, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 9, imagem 3 %32
    • I placed a clamp from end to end. This will prevent any exposure to hot parts, will allow movement of the battery and still maintain alignment.
    • Here is the two speed heatgun I use for my projects.
    • Simply apply constant heat to the tubing by moving the heatgun along the heatshrink tubing.
  10. Repairing Black and Decker 9074 Screwdriver  Battery: passo 10, imagem 1 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 10, imagem 2 %32 Repairing Black and Decker 9074 Screwdriver  Battery: passo 10, imagem 3 %32
    • Here is the battery with the heatshrink tubing attached.
    • Obviously the contacts are being than the connector. (The corrosion visible on the connector was cleaned of during the installation)
    • Trim the contacts with either a pair of sidecutters, or like in my case, use a pair of scissors.
  11. Repairing Black and Decker 9074 Screwdriver  Battery: passo 11, imagem 1 %32
    • Once the contacts are trimmed to size, the battery is ready for installation into the screwdriver. There is a separate guide for that. Total cost for this was around $9.00 for the cells.
Conclusão
7 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
782.480 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 544 guias
3 comentários
What are the specs on the batteries, and where did you get them? I don’t see any on mine. Thanks!
TerryG - Responder
eBay has the exact set the 4/5 sc sub c are the shorter ones easy to find with connecters already on each end of battery I'm rebuilding mine soon as they come in I'll post results
Corey Coker -
Thanks for the instructions.. Just a small point, when applying the heat gun (for thermal shrinking application) I think you better tell to use insulators or some kind of n insulation for the metal clamp, to avoid short circuit.. But thanks for all this anyways…
facehobi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 55
Duração total: 8,508
