Ir para o conteúdo principal
O Chrysler PT Cruiser é um automóvel familiar pequeno/MPV compacto de motor dianteiro e tração dianteira, fabricado e comercializado internacionalmente pela Chrysler nas carrocerias hatchback de 5 portas (2000–2010) e conversível de 2 portas (2005–2008).
Pt cruiser limp mode
Where should I begin to look for the cause?
This is really strange , my car shifts gears fine until I hit a good bump along the street. Once it hits a couple manhole covers or potholes the dash display flickers once or twice and the transmission stops shifting past second gear. I do not believe this is a mechanical problem because it always seems to happen when there's a few bumps or potholes? Has anyone had this problem and how did you find the issue? Where should I look,it strikes me as an electrical problem?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hi,
Get the OBDII port scanned for any fault codes.
This may be a good place to start to find out what is happening when the car is in limp mode.
I've read that some auto parts retail chains in the USA will do this for free
por
Adicionar um comentário
4 respostas
Pergunta mais útil
as previously mentioned in a comment, get the codes read. In the USA places like autozone and O'Reilly will do this for free. See what it says. The fact that a bump causes it tells me its almost certainly electrical. Loose grounds or plugs are likely culprits. Its going to suck, but you'll need to start chasing wires and double checking everything until you find the cause. Could be electrical connector to the transmission.
Esta resposta foi útil?
Pontuação 2
It is an electrical problem, it starts from the connection that reaches the transmission and sees separating the cables, it is probable that some have been damaged and they are making a short, it already happened to me and I solved it that way, with patience separate and if there are stuck cables, peel them off and tape them
Pontuação 1
Check the electrical connectors at the pcm and Tom under the hood
Pontuação 1
I too have a 2002 cruiser. My transmission stopped shifting gears out of no where . I was stuck of stupid until someone suggested that i change my transmission filter (never even heard of it,but yes it has one) once i changed it and the fluid itself. I have not had that problem since
Pontuação 1
Adicionar a sua resposta
Margaret Groot-Koerkamp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 2,030
