Ir para o conteúdo principal
O Samsung Galaxy Note II é um smartphone conhecido por combinar uma tela grande e um software otimizado para uma caneta stylus integrada que pode ser guardada no próprio aparelho.
Testing the device without a battery?
I recently got a as-is device lot for a iPod Classic 6th gen but this phone came with it, but no battery (SGH-T889), along with a Galaxy Core Prime I need to replace the LCD digitizer on and make sure the LCD is okay. However, due to the lack of battery with the Note II I cannot test it right now but I don’t see any AMOLED screen cracks. It also looks like the IMEI is clean. Sadly, I lost the battery from the Note II years ago.
That being said, I also have ANOTHER Note II I got years ago that was damaged by being broken in the most embarrassing way, but I have a known good AT&T board I have the unlock code for. My plans for this phone are if I can get it working great I’ll try and unlock it as well, but if I find something is off about it I have the AT&T board I can drop in and then I’ve finally gotten around to rebuilding it.
I have one coming, but is there a way known to work to get around these things demanding a battery to even TURN ON?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I have tried to get phones on without the battery as well, but I have had no luck. I would suggest just buying the battery and testing it that way. This is true with a lot of phones, they need the battery in order to turn on.
Esta resposta foi útil?
Pontuação 0
2 comentários:
It's not that I don't have one coming - I do. I was hoping I could quickly check the health of the phone and AMOLED panel.
por Compartilhar
@nick As far as I know there is no easy way to do that, so I would wait for your battery to come in.
por Compartilhar
Adicionar a sua resposta
Nick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 550
