Ir para o conteúdo principal
Why can't I install Windows 10?
I am trying to install Windows 10 via USB. I have formatted the USB, however, it doesn’t show up as UEFI. I have looked through BIOS and can’t find any way to change it. Additionally, sometimes when I reboot BIOS, i’ll receive the “Reboot and select proper boot device” message. Any help?
Specs:
MSI B450 Tomahawk Max
AMD Ryzen 5 3600
MSI 1070ti Aero
WD Blue 3D Nano SATA SSD M.2 2280
Corsair Vengeance DDR4 3600MHz
Corsair CX 550M
Esta é uma boa pergunta?
Pontuação 0
1 comentário
This question was migrated from https://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Solução escolhida
How are you writing the USB stick? If you’re using the Media Creation Tool, it writes it with a preference for UEFI boot modes on compatible systems. With these systems, you often need to have it set to UEFI boot for it to show as a boot option. In addition, you’re committing to keeping it as a “UEFI” system once you reinstall since changing back isn’t going to happen without a reinstall.
If you want to have some flexibility, you’ll need to use Rufus.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Justin Shifflett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 396
