Samsung A71 water damage!
Hello I have a Samsung A71 water damaged, it will not come on, when I'm trying to turn it on its only vibrating, then vibrating every 5 min or so.
I try hard restart pressing down volume and power.
I try and replaced the charging board no change.
Can it be the battery or display ?
Esta é uma boa pergunta?
2 comentários
my phone is still powered up but touch screen doesnt work , will it dry out after a period of time?
por skengineering
@skengineering sure it will dry out. As it does so it will leave all kinds of minerals deposited by water etc. behind. This will then cause corrosion (or even short-circuits in the components) and lead to complete failure. So, if that is the end result you are expecting let it dry on it's own. If you are expecting to use it again, follow the advice given in the answer provided.
por oldturkey03
