PCI LAN: Realtek PXE B09 D00
I have a pop-up on my daughter's laptop has this error that pops up and we can't get it off.
Esta é uma boa pergunta?
Check if you see a hard drive present in the BIOS - LAN boot (which is what this Realek PXE message you’re seeing is). PXE boot is a common sign of a bad hard drive or bad OS, but often a bad drive. If you see the hard drive, run Hiren’s Boot CD to see if the drive is present and reading data reliably. Once confirmed to be good, run a SMART test and do a self-test to make sure it isn't bad.
If the drive has detection issues, do not mess with it if you need her laptop to work - replace it.
Esta resposta foi útil?
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 77
Duração total: 3,488
