Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
678 Perguntas Visualizar todos
I dropped my phone on the bathroom floor and now its unresponsive
I dropped my phone and now the screen won’t respond to my touch except the bottom. I think I just knocked something out of place but I’m not sure. I want to fix it myself because I don’t wanna hear my uncle’s mouth about my phone being semi-broken again..help! Also, I already tried restarting it. Also is it possible for me to knock whatever is out of place into place??
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
There’s a pretty good chance that the screen was damaged by the drop and that would require a replacement screen. However, you may be luck and it could be a partially disconnected screen. So check out this guide and re-seat the screen connectors. Be careful when you do this and follow the guide to the letter, especially about disconnecting the battery first.
If the screen is properly connected, and a replacement screen doesn’t solve the issue, then you have a logic board issue.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Skylar Black será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 614
