Ir para o conteúdo principal
Guias para a versão LTE do iPad Mini 4—modelo A1550. Anunciado em 9 de setembro de 2015, o iPad Mini 4 é o sucessor do iPad Mini 3.
iPad mini 4 home button replacemnt
I’m repairing an iPad Mini 4 LTE that had a demolished screen - to the point where the wake/lock sensor and home button were almost non-existent.
I’ve installed the replacement screen and home button and was able to get into the settings and turn off the wake/lock feature to get around the need for the sensor. The home button works (no touch id of course), but the bracket isn’t quite stable enough - I used the double sided red adhesive that is normally used on the frame.
What is a standard adhesive to use with the home button brackets (short of using super glue)?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I usually use a good quality tape, either the 3M or Teva tape and then apply a bead of two-part epoxy around the bracket to give it a more solid feel. This is what’s done now right from the factory.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Bill Shannon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 362
