Ir para o conteúdo principal
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 Perguntas Visualizar todos
screen replaced, but buttons dont work
I recently replaced an evo screen like normal but this time when u hit home on the new screen or any of the bottoms button I get no response except for it hits the bottom of the phones option whatever is above the button I select Wat do I do ?????
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You likely didn't connect the cable going to the digitizer correctly. Before you do anything else, take the iPod apart again reconnect the digitizer until the connection is fully flat.
If this doesn't work and the rest of the iPod is good, you likely have a defective replacement digitizer.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks but I took it apart and realized the ribbon for the digitizer was pulled flush all the way through to the back of the lcd... it folded before touching the lcd not firm and pulled tight and flat thank you though started to go crazy
por
Adicionar a sua resposta
joe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,406
