Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Perguntas Visualizar todos
My dryer been over heating and now it doesn’t start.
I can’t figure out what’s wrong with my dryer please help. It worked fine and dried my clothes but the dryer would get pretty hot and now when I try to press start nothing happens. I can turn the power on and off but when I click the start it won’t start the dryer. It’s a kenmore elite smart heat quietpak 4 he3.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Anita Babak what is the exact model number for your Dryer?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Anita Babak there are several components that an cause your dryer not to start. It could be a faulty timer, thermal fuse, door switch, start button, or improper voltage. Start by testing the outlet first to make sure you are getting a full 240 volts. If you are not then, you will need to check your breakers. If you are, then you will need to test the internal components. There start with the thermal fuse, since it is the most common issue for a dryer and yours had shown signs of overheating already. The thermal fuse is located on the outside of the blower hosing. It is a small plastic part with two wires going to it. You need a multimeter and test for continuity.If you are getting continuity, then you will need to check the rest of the components.
I attached the tech sheet which should work for your dryer and will help you with the diagnostic and the repair of your dryer. ZB70972_W10156034A.vp
Esta resposta foi útil?
Pontuação 2
Solution 1:
Heating Element
The heating element warms the air before the air enters the dryer drum. If the element is partially shorted out, it may produce heat continuously, even if the dryer has reached the proper temperature. When this happens, the dryer gets too hot. To determine if the heating element is at fault, use a multimeter to test each terminal for continuity to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Dryer Heating Element WP8544771
Genuine OEM Part # WP8544771RC Item # 1180054Alternative Part Number(s)
Pontuação 1
2 comentários:
Where can I find the model number ?
por
On most Kenmore Elite dryers, the model number sticker is around the opening of the door. Open the dryer door and look around the outside of the door opening. Some dryers have the sticker on the bottom left or right side. Some dryers have the sticker on the top right side
por
Hi,
Check if the thermal fuse and thermal cut out fuse are both OK.
The thermal fuse if blown will prevent the dryer from starting and heating.
The thermal cut out fuse stops the dryer from overheating.
A faulty thermal cut out fuse would have allowed the heater to get too hot (which may have damaged the heater element -hopefully not) and caused the thermal fuse to blow, shutting off the power to the heater so as to prevent a possible fire
Pontuação 1
1 comentário:
Where is the thermal fuse located on the dryer?
por
Adicionar a sua resposta
Anita Babak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 33
Duração total: 1,323
