Ir para o conteúdo principal
ASUS Zenbook Flip S UX370UAK(antiga) / UX370UAR(nova) Conversível 2 em 1, suporte para caneta, leitor de impressão digital
What screw size is it?
I have Asus Zenbook ux430u and I want to replace some parts but I don’t know which screwdriver I should use.
Imagem
Esta é uma boa pergunta?
Pontuação 2
1 comentário
TORX T5. You'll find this in many kits.
por
Adicionar um comentário
1 resposta
Solução escolhida
T5 or T6 for the Zenbooks - it depends on which one you have, so I would get both just in case. It isn’t a TR Security at least, so that isn’t an issue. More then likely it’s T5 because that’s historically what Asus uses in the Zenbook, but T5 and T6 are very similar looking to a point on devices like this, it’s best to have both. It uses Phillips #00 screws like nearly every other laptop in the PC sector internally.
I would also get the 64-bit driver kit just in case it’s something obscure even what information I have doesn’t apply. You’re better off with the 64-bit driver kit since it isn’t that much more, if you want to save a few bucks, the Marlin screwdriver set will work. This only has the T6, so you’re taking a chance on if it will work or not as well.
Imagem de iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws.
Produto
Mako Driver Kit - 64 Precision Bits
$39.95
Imagem de Torx Security precision fixed blade screwdrivers in a handy case with built in sorting tray.
Produto
Marlin Screwdriver Set - 5 Torx Precision Screwdrivers
$21.95
Esta resposta foi útil?
Pontuação 1
5 comentários:
thank you very much:)
por
does anyone know what the actual size of the screw is as well? I'm trying to find replacements but I can't tell what the size is.
por
@Talal Hasan Usually Asus is T5 - look up the model and you'll know right away.
por
Guys, I lost them after I removed the screws. Can you tell me their model number? (like M2 * 4). There should be two kinds of screws on the D side.
por
@zpp eBay. Buy a bunch of them for a few bucks, but keep in mind unless you seek out T5/T6, they will be Phillips.
por
Adicionar a sua resposta
Anton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 99
Ao todo: 19,444
